Re: Coban TK-103
ok, let me try to help you.
first: you need to have a simcard which is enabled for gprs. As i know in Somalia you should use "Hormuud Prepaid"
find out the APN and username/password from your simcard provider. Just call their serviceprovider and ask them for this information.
second: create in WIALON a new unit by going to cms.online.stavtrack.com, login with your demo credentials.
go to "units", click to "create new unit", enter a name, enter the IMEI number of your TK103 in field "unique id", choose GPS-103B as "device-type" and click to ok.third: send following SMS to the phonenumber you put into the gps tracker: begin123456
device should answer with "begin ok".
send next sms with apn: apn123456 (name of the apn, for example apn123456 hormuud)
if your operator needs to set a username and password for gprs connections send following additional SMS:
send sms: up123456 username password (example up123456 gprs secret)now you need to set the IP adress and port:
send sms with text "adminip123456 193.193.165.165 20558" (always without quotations!)now you need to enable gprs:
send sms with text "gprs123456"last is typicaly to set the update intervall how often device should send.
(ask coban for this command, i dont have it here)by the way, device should always answer with some kind of OK.
Enjoy
Wolf.P.S. did you read the documents on http://docs.gurtam.com?
very usefull.
you should start with http://docs.online.stavtrack.com/en/hosting/user/quick/quick
