Wialon Hosting Release Notes
(21/09/2016 15:30:57 отредактировано Kirill Yakunin)
Тема: Wialon Hosting Release Notes
Before new functionality comes to stable release, it’s thoroughly tested in a separate Wialon version at dev.hosting.online.stavtrack.com.
We move on and introduce more flexible settings of Wialon Hosting versions.
Now there are three branches: Stable, Beta and Dev, where:
Stable is a branch with functionality which has undergone all stages of testing. It’s rarely updated with new features.
Beta is a branch containing the latest functions developed for the monitoring system. This branch is intended for the analysis of Wialon Hosting updates. Beta version is available for user DNS and http://hosting.online.stavtrack.com .
Dev is an established branch available at dev.hosting.online.stavtrack.com. Here you dip into the future and try most recent Wialon features. Dev version can still be used to try the new developments, whenever access to Beta is restricted by a top account.
In CMS Manager 'User Settings' dialog of a top user now contains 'Branches' tab. This tab provides a possibility to choose branches for user DNS available: Stable, Beta and Stable/Beta. The option “Stable/Beta” allows users for utilizing this DNS to be able to switch between branches on the login page of the monitoring system. In other words, if something goes wrong a user can always get back to the stable Wialon Hosting version.
The novelty is under development and the release is expected by the end of the day. Looking forward to your comments and suggestions to achieve the advanced user experience while using beta.
Marketing specialist, Gurtam
Re: Wialon Hosting Release Notes
Here is the list of recently added features to Beta branch.
-  The option to set maintenance duration in days, hours and minutes. read more here
- New options in managing messages in CMS Manager. Here is more.
- Night shifts data devision. More here.
- Additional geodata sources. Read this topic.
- Connection restoring notification. The setting is in "Connection loss" notification preferences
Tatsiana Shmihelskaya
Business Analyst, Gurtam
We add some new options and features in monitoring panel. Read more in the separate theme on the forum.
Try it in Beta version now!
Some new features for Beta branch users:
  • new possibility to ser XY table in sensors. read more in the separate theme
  • new design of the dialog "Modify unit groups" on notification tab "Measures when notification triggers"
We've updated Beta version today. Here is a list of the newest features:
  • New duration format was added to the report table properties. Now you can use hours with two decimal places to display duration in reports.
  • Initial and final mileage columns were added to the Engine hours report template.
  • Limit on fields in units' reference book was raised to 100.
  • Import and export of  'Secondary information' option in monitoring panel was supported
Fuel comsumption master is added to Sensor tab in Beta.
Now all functions for Stable version are ready. You have two weeks to leave feedback and requierments to correct new features. Then they will get to Stable version.
Follow us on Twitter – here you will find up-to-the minute information about new features in the system.
I want to introduce you new functions, that we've added to Beta branch recently
- What's new box.. Learn about the new features in updates in the interface.
- The system acquired 'Groups of passengers' and 'Passenger groups' report type.
- You can leave comments for notifications. Register a custom event upon receiving a notification and leave a comment that will be displayed under the 'Notification text' and in reports.
- We've added a possibility to put a mouse over the unit tooltip to copy information from unit tooltip.
- Search field was added to the dialog "Send mobile notification" in a notifications settings.
- As optimization is an important direction of our development, we made some optimizations to jobs and notification tables and to charts.
Try it all and have a good day!
We've added some new features for Beta recently:
- Modified mini-maps for Google Street View.
- Access to extended/additional information on units in the group view mode.
- New languages in CMS manager.
- Consumption by rates on Unit's tab 'Advanced'.
- Advanced filtering in “Messages” panel.
New features are available in Wialon Hosting (Beta):
- You can set sensors visualization directly in Locator, build tracks for several units, see the time of link expiration and Locator description in browser's tab title.
- Previously checked elements get to the top of the list.
- List-and-Tile views are added for Apps dialog, also you can try new search filter  and drag&drop option to replace apps in your list.
- We added the following math functions to messages panel filter: "<", ">", "=".
Some more new features for you in Beta:
- We got the first version of video streaming in Wialon.
- Report template tooltip now contains the information on report type, bound units, and the list of tables.
- We added filters by mileage in trips, violation name (mask) and duration to “Eco driving” report.
- We implemented parameters grouping in custom message sending dialog
- The tooltip now “freezes” upon pointing both on units and unit tracks.
- “Units” tab in CMS Manager has been supplemented with “Unit groups” column.
- Partners with Premium Package or Personal design got an ability to change logo in Locator.
- You can add a new geofence to one of the existing groups when creating it.
Share your opinion with us, please!
We had Wialon Hosting Beta update recently.
Here is a list of new features:
- ability to open horizontal panels "Messages", "Reports", "Routes" to the full height (see on the screenshot).
- custom settings for notification triggering, including the timeout, minimum duration of the previous and alarm states instead of interval presets.
- new options for Google map routing: "Optimize points order", "Avoid toll roads" and "Avoid ferries".
  • Wialon Hosting Release Notes
Wialon Hosting Beta Update:
Dear Wialon users, please meet VIN decoding feature in this update. The full description of the feature you may find on our blog.
All your feedback, ideas and thoughts are warmly welcomed at p.bushuev@gurtam.com
Pavel Bushuyeu
Product Owner, Mobile
New features are available in Beta:
- We added an ability to create reports using geofences from all the available resources in tables "Geofences", "Non-visited geofences" and "Rides".
- Added a separate “Connection restore” notification with the option to set specific notification parameters and actions.
- New action in notifications: unit icon change when the corresponding notification is triggered.
- Automatic verification of user names when you create or edit a new user to exclude the names already existing in the system.
Read more details in our weblog.
- We added a new option for charts in reports. It allows you to divide the chart by days or weeks while saving it in a file.
- User password is checked for complexity now while changing it or creating a new user. The minimum password length is 4 characters.
- For multi-colored tracks we added a separate option in the track panel and report settings "Map output"
Read more on the weblog.
- two-factor authorization.
- list of available users in "Login as" feature on the login page.
More information and pictures find out in our weblog.
We released the Wialon Beta update. That is the last features scope, which Wialon Local will include. Hope, everyone will find something useful for your daily business.
Here is the list:
- The new billing service for unit deactivation control.
- Google panorama view by clicking on the stop and parking markers in reports and track panels.
- The changes in the design of errors on the login page and tasks and notifications dialogs.
- The new geofences filtering in notifications types "Connection loss" and "Idling".
- The new tool for visualizing changes in a service and service usage named Dashboard in the CMS manager.
- Redesign of the report templates dialog.
- The simple calculator in the tables "Engine hours", "Trips", "Summary".
The full description of the features you may find on our weblog, documentation and forum topics.
On April 11 the following improvements were installed to Wialon (Beta):
- A new column for the battery sensor is added to the monitoring panel. Choose the sensor in the unit properties on the "Advanced" tab.
- We added an ability to send email notifications about oncoming account blocking.
- In addition to the option "Geozones instead of addresses", we added an ability to see the remaining distance to the selected geofences.
- New % ZONE_DECS% tag to add a geofence description to the notification text.
- MGRS coordinates. Can be launched to your service by request.
- Engine hours counter with accuracy to two decimal places
- An option for rendering track color by trips has been added in "Advanced" unit tab.
- One more improvement for 2Auth. If the first code was not delivered, then you have a chance to send it one more time.
More details and examples read on our blog.
Welcome our new Beta release:
- Notifications filtration for TOP and dealer users. You can select the resource and the type of notifications you want to receive in “User settings”
- Redesigned unit tooltip and extended information. We redesigned the unit tooltip and extended information: added the unit icon and structured the content into blocks in an easy-to-grasp form.
- Possibility to get an overseeding note in a corresponding report from one message with a violation.
Read more on our updated pretty blog.
Briefly about the today's Beta update:
- We added the export function for retranslator with units list in CMS manager.
- Supported weather layers OpenWeatherMap and Aerisweather.
- Added a geofence filter in the report table "Eco driving" for a units group.
- All reports support LBS coordinates.
Read more in our blog.
I'd like to inform you that we have changed the cycle of WialonHosting updates. They will be released more often now. But according to the old tradition, all new features are installed in Beta first. So, today the following functions were installed:
- After the unit is selected in the monitoring panel, the system centers the map and zooms it to the unit location. We pre-set the optimum zooming level and made it standard for all users.
- Security first: if a user logs in to the system for the first time, he’ll have to set up the new password instead of the existing one. This user will be the only one who knows the updated password.
- Binding reports to dynamically updated unit groups. If units enter or leave groups when a certain event occurs, you can still bind them to reports. In that case, units bound to reports will appear and disappear depending on their presence in that group.
- Seasonal fuel consumption rates. Check out “Advanced” tab in “Unit Properties” and find "Winter consumption" checkbox. Activate it, select the season duration and start simple fuel management.
Read more about Wialon and other Gurtam products' updates in our blog.
- Added sorting by “Time” in messages table – new-to-old and vice versa.
- Optimized the rendering of the map attached to reports. Thanks to this you export reports into files quicker.
- Added the option of binding flespi and Wialon top user in "User settings".
We updated a dialogue of shift registration and viewing drivers/trailers/passengers bindings in Wialon Beta today. Actions with bindings become much faster.
In the next Wialon Stable update will also install the calculator function improvement. The function will be available for all report tables, except "Statistics," "Images" and "Video".
Watch the "What's new" star in the bottom Wialon panel!
Try out the new features in Beta:
- You can see addresses from Google source in reports if you use Google key from Gurtam.
- You can choose an icon for overlapping units on the map in user settings.
- After you create new units in CMS, they will be automatically added to the creator's monitoring panel.
