Problem with email account
Тема: Problem with email account
Hello
I am using Wialon Local 1504 (build: 2016-09-16 14:12) with G suite (old app google account).
There are three SMTP options with G Suite account:  a) smtp-relay.gmail.com , b)    smtp.gmail.com     and c) aspmx.l.google.com with port (25, 465, or 587), (465, or 587) or (25).
I had tried all the possible combinations at Mail System information menu and only using smtp.gmail.com:587 as SMTP server information with my login and password from gmail is partially working. What I means is I request a verification I got inmediatly an email with ¨Dear Wialon Local Customer,
Mail system is working properly.
Best Regards,
Gurtam¨
Thats is perfect!
However, using automatic task or notification where email es required, The email doesnot work.
From logs files I got ¨date time  email_service::bg_thread:send failed (return code: 530 to: destination@email.com  and email deleted: Notification name¨
I had added the ip address to the white list at google  configuration and a lot others idea without sucess.
Please any help ?
Thanks in advance
Re: Problem with email account
Hello
After installation of wialon local, do you caonfigurate postfix manually?  Hostname? user? password?
Thanks in advance
yikes
hi,
there is a postfix installed out-of-the box with your Wialon Local. Why not use it?
Also maybe you'll find some clue here - https://docs.online.stavtrack.com/en/local/admin/ … ail_system
Please share
