Can I put two libraries in one session?
Тема: Can I put two libraries in one session?
Hi,
I need to get the sensor unit and run a report, Can I put two libraries in one session?
Example:
var sess = wialon.core.Session.getInstance();
        sess.loadLibrary("resourceReports");
        sess.loadLibrary("unitSensors");
or some suggest, thanks.
Re: Can I put two libraries in one session?
Denisse, of course You can.
Thank you, but I have a problem because perhaps the proccess of execute the two libraries cause a collision because the first execute found the sensors and execute the report ok but, the second time only to get sensors or report its depend.
Is this is because threads in the process?
Add a code of example.
var res_flags = wialon.item.Item.dataFlag.base | wialon.item.Resource.dataFlag.reports;
    var unit_flags = wialon.item.Item.dataFlag.base | wialon.item.Unit.dataFlag.sensors | wialon.item.Unit.dataFlag.lastMessage;
        var sess = wialon.core.Session.getInstance(); // get instance of current Session
        sess.loadLibrary("resourceReports"); // load Icon Library
        //sess.loadLibrary("unitSensors");
        sess.updateDataFlags( // load items to current session
                type: "type",
                data: "avl_resource",
                flags:res_flags ,
                mode: 0
            }, // especificación del recurso
                    type: "type",
                    data: "avl_unit",
                    flags: unit_flags,
                    mode: 0
                }], // especificacion de unidades
                function (code) { // updateDataFlags callback
                    if (code) {
                        msg(wialon.core.Errors.getErrorText(code));
                        return;
                    } // exit if error code
                var res = sess.getItems("avl_resource");
                if(!res || !res.length){
                    msg("Resources not found");
                    return;
                for (var i = 0; i< res.length; i++) // construct Select object using found resources
                    $("#res").append("<option value='" + res[1].getId() + "'>" + res[1].getName() + "</option>");
        getTemplates(); // update report template list
        $("#res").change( getTemplates ); // bind action to select change
                 // get loaded 'avl_unit's items
            var units = sess.getItems("avl_unit");
            if (!units || !units.length){
                    msg("Units not found");
                    return;
                } // check if units found
            for (var i = 0; i< units.length; i++){ // construct Select object using found units
                var u = units[i]; // current unit in cycle
                // append option to select
                $("#units").append("<option value='"+ u.getId() +"'>"+ u.getName()+ "</option>");
                        //getSensors(); // get Sensors for currently selected unit
            // bind actions to selects
            //$("#units").change( getSensors );
                        // getSensors(); // get Sensors for currently selected unit
            //$("#sensors").change( getSensorInfo );
            // bind action to select change event
            $("#units").change( getSelectedUnitInfo );
        var sess1 = wialon.core.Session.getInstance();
        sess1.loadLibrary("unitSensors");
        sess1.updateDataFlags(
                [//pecificación del recurso
                    type: "type",
                    data: "avl_unit",
                    flags: unit_flags,
                    mode: 0
                    if (code) {
                        return;
                    var units = sess1.getItems("avl_unit");
                    return;
            //$("#units").change( getSelectedUnitInfo );
Denisse, look at this playground example with corrected code:
https://sdk.online.stavtrack.com/playground/1ySsARS7
Thank you for this information deal
