Ignition sensor on a DCT Syrus
Тема: Ignition sensor on a DCT Syrus
I am working with a dct syrus device. When I want to configure the engine ignition sensor, I have problems since I use the parameter “event” to indicate when the engine is on. The bad thing about this, is that in this parameter all the different events configured show up, like the panic button, the aggressive movement, engine on and off. So I can not configure this sensor correctly. Someone can help me or tell me what can I change in my script for Syrus device, so I can have the ignition parameter correctly.
(04/10/2017 14:51:57 отредактировано jhdeguate)
Re: Ignition sensor on a DCT Syrus
crvg19 in Wialon you have to use "in9" (input 9) as parameter to sense ignition,  In your script you have to use "F00" to send the ignition status on unit, as this:
>SED00NA0;F00+< # Ignition ON
>SED01NA0;F00-< # Ignition OFF
Regards,
Jary Hernandez
Thanks for your help, but still no luck.
Stil with the same problem. If you can check my script, cause we dont find where is the error.
Regards,
Carlos Valdez
Иконка вложений script de wialon.txt 2.21 Кб, файл был скачан 940 раз(а)
Test
>SXAEFC;VO;IO<
