Тема: Internal ID in CMS
Is it possible to add internal objects ID in CMS columns?
it would help for support when working with API
thanks
thanks
I'm not sure, that CMS is often used by developers. But all other users would get unnecessary information.
From the other hand search_items request is basic for developers. And it provides you IDs.
Anyone can use it, just insert your sid.
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=core/search_items¶ms={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid=
locationGPS, use custom fields for this.
we use customs fields already...but it was simple to see it directly as a column.
ok, forget it,
thanks
