Тема: display the description of geofence
hi
when i put the mouse on a geofence on the map it dosen't display the description of that geofence (if the geofence have no picture to icon attached to)
is the is a posibility to add this feature
hi
Hi!
If geofence doesn't has icon then in order to seed tooltip with description (name, type, list of units inside, etc.) you need to press CTRL and put the mouse cursor over geofence. https://docs.online.stavtrack.com/en/hosting/user/geo/usage
If you mean just geofence name then make sure that option 'Display names of geofences on map' is enabled in User settings https://docs.online.stavtrack.com/en/hosting/user/set/general
