Тема: error 1 и error 1003
Как корректно обрабатывать ошибки связанные со входом и истекшей сессией?
Из-за непонимания алгоритма получил вечную рекурсию.
Пока код такой
# -*- coding: utf-8 -*-
from urllib.request import Request,urlopen,install_opener,build_opener,ProxyHandler
from urllib.parse import urlencode
import json,os,time
class Tracker:
base_url = "https://hst-api.online.stavtrack.com"
sid = None
api_key = None
object_ids = None
def __init__(self,api_key,name,sid=None):
#install_opener(build_opener(ProxyHandler({"http": "http://proxy:3128","https":"https://proxy:3128"})))
self.api_key = api_key
self.name = name
self.sid = sid or self.login(api_key,name).sid
def request(self,svc,params):
data = urlencode({"sid":self.sid,"svc":svc,"params":json.dumps(params)},safe=":/{},")
headers = {"Content-Type": "application/x-www-form-urlencoded; charset=utf-8","Content-Length": len(data)}
try:
with urlopen(Request(self.base_url+"/wialon/ajax.html",bytes(data,"utf-8"),headers),timeout=2) as resp:
data = resp.read()
print(data)
if isinstance(data,bytes):data = str(data,'utf-8')
data = json.loads(data)
if isinstance(data,dict) and "error" in data.keys():#если истекла сессия то повторный логин и запрос
if data["error"] == 1:
self.login()
if data["error"] == 1003:
print("Waiting for wialon ready")
time.sleep(60)
if self.sid:
return self.request(svc,params)
return None
else:
return data
except:
print("Wialon timeout")
return None
def login(self,api_key=None,name=None):
#print("WialonLogin():%s"%self.sid)
self.sid = None
data = self.request("token/login",{"token":api_key or self.api_key,"operateAs":name or self.name})
if data:
if "error" in data:
return self
self.name = data["user"]["nm"]
self.sid = data["eid"]
objects = None
if "mongr" in data["user"]["prp"].keys():
gobjects = json.loads(data["user"]["prp"]["mongr"])
objects = []
for k,v in gobjects.items():
objects += v
if "monu" in data["user"]["prp"].keys() and not objects:
objects = json.loads(data["user"]["prp"]["monu"])
#self.object_ids = [int(x) for x in objects]
#print(self.object_ids)
#self.object_params = self.track(self.object_ids)
return self
def objects(self,ids=None):
#print("WialonObjects():%s"%self.sid)
data = self.request("core/search_items",{"spec":{"itemsType":"avl_unit","propName":"id","propValueMask":"*","sortType":"id"},"force":1,"flags":4194321,"from":0,"to":0})
if data:
data = data["items"]
else:
return None
objects = {}
for i,v in enumerate(data):
v["uri"] = os.path.basename(v["uri"]).replace("svg","png")
if ids:
if v["id"] in ids:
objects[v["id"]] = v
else:
return objects
def track(self,objects):
return {x["i"]:x["d"] for x in self.request("core/update_data_flags",{"spec":[{"type":"col","data":objects,"flags":4194304,"mode":1}]})}
def tokenList(self,user=None):
return self.request("token/list",{"userId":user} if user else {})
def tokenCreate(self,name,access=-1,objects=[],params={}):
return self.request("token/update",{"callMode":"create","app":name,"at":0,"dur":0,"fl":access,"items":objects,"p":json.dumps(params)})
def tokenDelete(self, token):
return self.request("token/update",{"callMode":"delete","h":token})
def update(self):
with urlopen(self.base_url+"/avl_evts?sid=%s"%self.sid) as resp:
data = json.loads(resp.read().decode("utf-8"))
if "error" in data.keys() and data["error"]==1:#если истекла сессия то повторный логин и запрос
return None
else:
return data
Не могу придумать как лучше обрабатывать ошибку 1. и сопутсвующие 1003 если попытаться перелогиниться немедленно.
