Dear hasan.ahmed,
thank you for your request!
I am sure that there are many other ways to add drivers' names to the monitoring without dividing the unit's name into 2 fields
I am of an opinion that the "Custom fields" feature will fully satisfy your needs. It is possible to display custom fields in the monitoring: both in the monitoring's extended unit information and in the unit's pop up with details. You can read about it here https://docs.online.stavtrack.com/en/hosting/cms/units/fields and here https://docs.online.stavtrack.com/en/hosting/user … _s_tooltip . Should be enabled proper setting in the User Settings: "Show Additional Information about the Unit" part - "Custom fields" option should be added to the monitoring's details and\or to the unit's tooltip.
Moreover, there is a separate tab "Drivers" created specially for your purposes. You (or your customers) could create the drivers they have in the "Drivers" tab and link them with the proper units.
The information about linked driver could be added to the monitoring as a separate icon. To do so open "Monitoring panel customizer" and enable the Driver's info, choose the type of info you want to be displayed. See how it could be worked out in my example attached.
Or you could display linked drivers as a detailed information in the monitoring details or in the unit's tooltip. The proper option should be enabled in the Unit's Settings: "Show Additional Information about the Unit" part - "Driver's activity" option should be added to the monitoring's details and\or to the unit's tooltip.
Please let me know if any help is needed with any option - I will be glad to assist you with making the system comfortable for you.
Thank you!
Maryia Paklonskaya
Wialon Business Analyst
