Get Unit ID by API
Тема: Get Unit ID by API
Sometimes a unit is created on the GUI and not through API. For those units, is there an API I can use to retrieve the unit id (by using the unique id for example)?
I need the unit ID for a lot of the APIs and if the unit was created through GUI, then I am not sure how I can call these APIs without knowing the unit id.
Get Unit ID by API
(06/04/2021 17:44:34 отредактировано hhamedk)
Re: Get Unit ID by API
rony.azrak, what you need is easily possible. You just need to use search method:
http://sdk.online.stavtrack.com/wiki/en/sidebar/r … arch_items
Everything is clear in document but let me know if you faced any problem.
