Login
Тема: Login
I am new in the use of the sdk Java of wialon. I would simply like all to connect me to the hosting
of wialon via my application server to get back certain information.
Here is the class which I established for the authentification.
public class WialonGeoZone
    private final static Logger logger = LoggerFactory.getLogger(WialonGeoZone.class);
    private String sessionId;
    private long resourceId;
    private final String parentLink = "http://kit-api.online.stavtrack.com/wialon/ajax.html?";
    private Session session;
    public WialonGeoZone()
        session = Session.getInstance();
        logger.info("session it is initialize");
        sessionId = null;
        resourceId = -1;
    public void login()
        // TODO : Change logic implementation of this method
        logger.info("Beginning login Wialon SDK");
        boolean b = session.initSession("http://kit-api.online.stavtrack.com");
        session.loginToken("251a59d6b516d93194ebc406b8a79d19EB12425ABF6BDFEFA7C8E0D9954A5C4C235943A8",
                new ResponseHandler()
                    @Override
                    public void onSuccess(String response)
                        super.onSuccess(response);
                        System.out.println(response);
                        logger.info("Login is executed with success");
                        logger.info("User Wialon it is "+session.getCurrUser().getName());
                        obtainSessionId();
                        logout(1);
                    @Override
                    public void onFailure(int errorCode, Throwable throwableError)
                        super.onFailure(errorCode, throwableError);
                        System.out.println(errorCode);
                        logger.info("Login is execute with error");
                        logger.info("Error code it is "+errorCode);
                        if(throwableError != null)
                            logger.error("Error login is caused by "+throwableError.getMessage());
                        else
                            logger.error("Error login. ThrowableError it is null");
    public void logout(int flags)
        session.logout(flags, new ResponseHandler()
            @Override
                logger.info("Logout is executed with success");
            @Override
                logger.info("Logout is execute with error");
    private void obtainSessionId()
        if(session.getId() != null)
            sessionId = session.getId();
            logger.info("SessionId it is : "+sessionId);
As mentioned in the documentation me got back my token from this link http://hosting.online.stavtrack.com/login.html by registering my to user name and my password.
But I receive an error (error code 8) message indicating to me that my user name or my password is not valid.
Then I tried with this code.
        sessionId = null;
        resourceId = -1;
    public void login()
        session.login("user_name","password",
                    @Override
                        obtainSessionId();
                        logout(1);
                    @Override
                        else
            @Override
            @Override
But I always receive the same error (error code 8).
However I arrive well at me connected to wialon hosting with my identifiers.
Sorry for my bad english.
Login
Re: Login
christian.amani, there is special auth form for Kit http://kit.online.stavtrack.com/login.html.
Generate token with it. http://hosting.online.stavtrack.com/login.html form is only for Hosting.
Login
Re: Login
Thank Thank, Very Thanks
Login
Re: Login
I'm working in application with login form separate to wialon and I'm arrived to a step that I should get a sensor value from wialon server.
How I can login to wialon without wialon form ?
I'm developing using LARAVEL and wialon local so which prefer working with SDK or REMOTE API
Thank you in advance!
