error 4 exec core batch with clean up resul
Тема: error 4 exec core batch with clean up resul
Hello, i execute my report with sdk wialon php by core batch but when i clean the result report show me error 4.
When i send the request (batch) without cleanup_result_report the batch request  funtionally fine.
When i'm try send the request batch only with cleanup report resul and again get error 4.
When i'm send the request (cleanup result) whitout bath funcionally fine.
i have try it for 2 and always get error 4.
way1  [{"svc":"report\/cleanup_result","params":[]}]
way 2 : [{"svc":"report/cleanup_result","params":[]}]
Thanks in advantaje.
(15/12/2016 11:49:22 отредактировано deal)
Re: error 4 exec core batch with clean up resul
cerpas, report/cleanup_result request in batch is workin correctly:
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=core/batch&params=[{"svc":"report/cleanup_result","params":{}}]&sid=<sid>
But there is no need to call one request in batch. It is usefull to combine numerous requests in one batch.
My user is desarrollador, I am use the sdk php.
For me is not working
http://hst-api.online.stavtrack.com/wialon/ajax.h … mp;params=[{"svc":"report\/exec_report","params":{"reportResourceId":23125,"reportTemplateId":0,"reportObjectId":13846903,"reportObjectSecId":0,"interval":{"flags":0,"from":1481608800,"to":1481867999},"reportTemplate":{"n":"Dispatch Fuel","ct":"avl_unit","p":"","tbl":[{"n":"unit_engine_hours","l":"Fuel","f":2097424,"c":"time_begin,time_end,trailer,fuel_consumption_imp,fuel_consumption_ins","cl":"Beginning,End,Trailer,By Impulse,By Instant","sl":"","s":"","p":"{\"grouping\":\"{\\\"type\\\":\\\"day\\\"}\",\"sensor_name\":\"*Fuel Dispensado*\",\"duration_format\":\"0\"}","sch":{"y":0,"m":0,"w":0,"f1":0,"f2":0,"t1":0,"t2":0}}]}}},{"svc":"report\/select_result_rows","params":{"tableIndex":0,"config":{"type":"range","data":{"from":0,"to":65535,"level":1}}}},{"svc":"report\/cleanup_result","params":[]}]&sid=<sid>
But i remove the request cleanup result it's works fine
http://hst-api.online.stavtrack.com/wialon/ajax.h … mp;params=[{"svc":"report\/exec_report","params":{"reportResourceId":23125,"reportTemplateId":0,"reportObjectId":13926449,"reportObjectSecId":0,"interval":{"flags":0,"from":1481608800,"to":1481867999},"reportTemplate":{"n":"Dispatch Fuel","ct":"avl_unit","p":"","tbl":[{"n":"unit_engine_hours","l":"Fuel","f":2097424,"c":"time_begin,time_end,trailer,fuel_consumption_imp,fuel_consumption_ins","cl":"Beginning,End,Trailer,By Impulse,By Instant","sl":"","s":"","p":"{\"grouping\":\"{\\\"type\\\":\\\"day\\\"}\",\"sensor_name\":\"*Fuel Dispensado*\",\"duration_format\":\"0\"}","sch":{"y":0,"m":0,"w":0,"f1":0,"f2":0,"t1":0,"t2":0}}]}}},{"svc":"report\/select_result_rows","params":{"tableIndex":0,"config":{"type":"range","data":{"from":0,"to":65535,"level":1}}}}]&sid=<sid>
I'll try execute only cleanup result is not working
http://hst-api.online.stavtrack.com/wialon/ajax.h … mp;params=[{"svc":"report\/cleanup_result","params":[]}]&sid=<sid>
Request fail if I include a clean up result report, I dont understand because its happens.
Thank you so much of your time.
cerpas, instead of "params":[] use "params":{}.
deal пишет:
I got it, thank you so much.
deal пишет:
but this error is from sdk
cerpas, when You call such request everything is fine:
var res = wialon.core.Session.getInstance().getItem(555);
wialon.core.Remote.getInstance().startBatch("cleanupBatch");
res.cleanupResult();
wialon.core.Remote.getInstance().finishBatch(null, "cleanupBatch");
deal пишет:
Yes with JS SDK is fine, but SDK PHP is not working fine.
Here's 3 variants of working code
    # ?params=[]
    $params = array();
    $result = $wialon_api->report_cleanup_result(json_encode($params));
    echo "<p>$result</p>";
    # echo: {"error":0}
    # ?params={}
    $params = new ArrayObject();
    # echo: {"error":0}
    # core/batch, ?params=[{svc:'report/cleanup_result',params:{}}]
    $params = array();
    array_push($params, array(
        svc=>'report/cleanup_result',
        params=>new ArrayObject()
    $result = $wialon_api->core_batch(json_encode($params));
    # echo: [{"error":0}]
