How to get Unit Last update date and time
Re: How to get Unit Last update date and time
By default report result has UTC+0 timezone.
To apply user's timezone to report result, after login it needs to execute request  render/set_locale
Then you can execute reports, get PDF file.
For example, timezone +5.30 = "tzOffset":134237528
"tzOffset" value includes DST settings (no DST = 0x08000000 = 134217728 )
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=render/set_locale&sid=02b93b7a37e3ce1510908253b4db8902
params: {"tzOffset":134237528,"language":"en","flags":256,"formatDate":"%m-%E-%Y %H:%M:%S"}
Note: also it may need to url-encode special symbol %
Diana пишет:
thanks for the response,
Here if the customer location is in Saudi Arabia and maybe a different location then do we need to update each time different time zone
How to execute a command for different requests
With search_item API we got different command and each command have different execution, on which flag we set a condition to user selection
core/search_item&params={"id":29916,"flags":512}
    "item": {
        "cmds": [
                "n": "إطفاء المحرك",
                "a": 1,
                "t": "tcp,gsm,vrt",
                "c": "custom_msg",
                "p": "Out 1,0"
                "n": "تشغيل المحرك",
                "a": 1,
                "t": "tcp,gsm,vrt",
                "c": "custom_msg",
                "p": "Out 1,1"
                "n": "Arnavi 2",
                "a": 1,
                "t": "tcp,gsm,vrt",
                "c": "custom_msg",
                "p": ""
                "n": "إعادة تشغيل الجهاز",
                "a": 1,
                "t": "tcp,gsm,vrt",
                "c": "custom_msg",
                "p": "reset"
    "flags": 512
1) Sent message option to execute a command
2) Reset option to execute the command
3) simple Execute commands
How i can differenciate this response value of t,c and p for different units,
svc=unit/exec_cmd&params={"itemId":55873,"commandName":"custom_msg","linkType":"tcp,gsm,vrt","param":"","timeout":10,"flags":0}
  • How to get Unit Last update date and time
(01/01/2021 14:39:02 отредактировано trushal.shah)
Diana пишет:
trushal.shah пишет:
Thanks for the solutions,
Last point that how I can get the movement of the units with start and [Between each] endpoint the day, or between dates
To get history data of events (trips, ignition) you need to execute  events/load & events/get
First you load events for some period  - , then get  it
For example,
Get trips from Oct 1 - Oct 5 , unix time UTC+0
Load events
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/load&params={"ivalType":1,"itemId":214,"timeFrom":1601510400,"timeTo":1601942399,"detectors":[{"type":"trips","filter1":0}]}&sid=028384ac3f02f18c414208758685b320
Get result
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/get&params={"selector":{"type":"trips","timeFrom":1601510400,"timeTo":1601942399,"detalization":3}}&sid=028384ac3f028758685b320
Hello
Thanks for your support,
if you can please support us for below query
Event Load:
{"ivalType":1,"itemId":54533,"timeFrom":1609007400,"timeTo":1609093799,"detectors":[{"type":"trips","filter1":0},{"type":"ignition","filter1":0}]}
Get Event
svc=events/get&params={"selector":{"type":"*","timeFrom":1609007400,"timeTo":1609093799,"detalization":11}}
Here how we can get stop details of the unit movement for track pages
please check the screenshot, we need to display the same stop icon on the map
The Stops are the part of trips where speed is less than min value speed in Trip Detector. So if you need stops intervals you can request events trips with selected speed (custom intervals expressions)
For example, the min speed value = 1 km/h, so "expr":"trips{s<1}" means intervals where speed (s) less than 1 km/h
First load trips
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/load&params={"ivalType":1,"itemId":21728414,"timeFrom":1609718400,"timeTo":1609804799,"detectors":[{"type":"trips","filter1":0}]}&sid=02b93b7a37e3ce1510908253b4db8902
Then request intervals with speed < 1 km/h
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/get&params={"selector":{"expr":"trips{s<1}","timeFrom":1609718400,"timeTo":1609804799,"detalization":1}}&sid=02b93b7a37e3ce1510908253b4db8902
Response
{"trips":{"0":[{"from":{"t":1609753417,"y":43.3473701477,"x":-8.48857975006},"to":{"t":1609753448,"y":43.2673683167,"x":-8.48857975006},"m":0,"f":0},{"from":{"t":1609753490,"y":43.2673683167,"x":-6.4885802269},"to":{"t":1609753530,"y":43.1673698425,"x":-6.34601783752},"m":0,"f":0},{"from":{"t":1609754439,"y":42.4268341064,"x":-8.6491394043},"to":{"t":1609754439,"y":42.4268341064,"x":-8.6491394043},"m":0,"f":0}]}}
Diana пишет:
First load trips
Response
Hi, thanks for the reply
we got the response trips{s<1} with this condition but same time we need trips data also
so how I can get all movement of the vehicle with stop, parking, and  trips in single response
There is not parking intervals in response.
You can get only trips, and trips with less speed (stops).
The parkings are calculated as difference between trips time.
First load, then get all full trips, and then get trips intervals (with speed less) as stops.
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/load&params={"ivalType":1,"itemId":21728414,"timeFrom":1609718400,"timeTo":1609891199,"detectors":[{"type":"trips","filter1":0}]}&sid=026499c89bc755056c401314b35bfa9f
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/get&params={"selector":{"type":"trips","timeFrom":1609718400,"timeTo":1609891199,"detalization":1}}&sid=026499c89bc755056c401314b35bfa9f
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=events/get&params={"selector":{"expr":"trips{s<1}","timeFrom":1609718400,"timeTo":1609891199,"detalization":1}}&sid=026499c89bc755056c401314b35bfa9f
All 3 requests can be execute at one svc=core/batch
Format like
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=core/batch&sid=026499c89bc755056c401314b35bfa9f&params={"params":[{},{},{}]}
where JSON object in array is a request {"svc":"...","params":{...}}
Example
https://hst-api.online.stavtrack.com/wialon/ajax.html?svc=core/batch&sid=026499c89bc755056c401314b35bfa9f&params={"params":[{"svc":"events/load","params":{"ivalType":1,"itemId":21728414,"timeFrom":1609718400,"timeTo":1609891199,"detectors":[{"type":"trips","filter1":0}]}},{"svc":"events/get","params":{"selector":{"type":"trips","timeFrom":1609718400,"timeTo":1609891199,"detalization":1}}},{"svc":"events/get","params":{"selector":{"expr":"trips{s<1}","timeFrom":1609718400,"timeTo":1609891199,"detalization":1}}}],"flags":0}
The response will contain full trips (in example 5 full trips) and stops intervals (in example 6 intervals)
[{"events":{"trips":{"0":5}},"states":{"trips":{"updateTime":1606694400}},"selector":{}},{"trips":{"0":[{"from":{"t":1609740136,"y":46.8365631104,"x":-2.789290905},"to":{"t":1609740381,"y":46.3055648804,"x":-2.789290905},"m":1609740681,"f":2},{"from":{"t":1609747691,"y":46.3055648804,"x":-2.789290905},"to":{"t":1609748071,"y":43.3003921509,"x":-2.0059273243},"m":1609748385,"f":2},{"from":{"t":1609748558,"y":43.3003921509,"x":-2.0059273243},"to":{"t":1609748851,"y":43.4693832397,"x":-3.83861064911},"m":1609749180,"f":2},{"from":{"t":1609749642,"y":43.4693832397,"x":-3.83861064911},"to":{"t":1609750584,"y":43.3473701477,"x":-8.48857975006},"m":1609750884,"f":2},{"from":{"t":1609753417,"y":43.3473701477,"x":-8.48857975006},"to":{"t":1609754439,"y":42.4268341064,"x":-8.6491394043},"m":1609754768,"f":2}]}},{"trips":{"0":[{"from":{"t":1609740321,"y":46.3055648804,"x":-2.789290905},"to":{"t":1609740351,"y":46.3055648804,"x":-2.789290905},"m":0,"f":0},{"from":{"t":1609747781,"y":46.2055625916,"x":-2.98929095268},"to":{"t":1609747981,"y":43.3233222961,"x":-2.00242733955},"m":0,"f":0},{"from":{"t":1609748041,"y":43.3003921509,"x":-2.0059273243},"to":{"t":1609748041,"y":43.3003921509,"x":-2.0059273243},"m":0,"f":0},{"from":{"t":1609748588,"y":43.3103904724,"x":-2.0059273243},"to":{"t":1609748822,"y":43.4533843994,"x":-3.83861064911},"m":0,"f":0},{"from":{"t":1609750500,"y":43.3473701477,"x":-8.40155792236},"to":{"t":1609750500,"y":43.3473701477,"x":-8.40155792236},"m":0,"f":0},{"from":{"t":1609753595,"y":42.4268341064,"x":-8.6491394043},"to":{"t":1609754408,"y":42.4268341064,"x":-8.6491394043},"m":0,"f":0}]}}]
If you need to load trips from new interval, you need to execute request svc=events/unload, then load new intervals.
Diana пишет:
Format like
Example
Hi, thanks for the reply this works
but still, there is wrong location data on the map of the parking and stop comparing with webpenal
All data under s>1 consider as stop with less than 5 min different
As we compare with backend penal and mobile few locations consider as parking is considered as stop in the mobile.
1)i have attached a file of the response
2) screenshot of the web model with stop and parking
3) Mobile same request data with stop and parking
which condition would make can get same stop and parking location as web track on the map
Иконка вложений Platinum till 6pm.docx 14.81 Кб, файл был скачан 298 раз(а)
Hello, trushal.shah
There are used different algorithms (Real-time Data Processing vs Processing Messages from the Database upon Request)  to proceed data via events (for example, Wialon mobile app) and Tracks on web site,
More about it here https://docs.online.stavtrack.com/en/hosting/user/data/data.  The results depends on the unit data - how it sends, what parameters and etc.
Unfortunately, it's hard to understand what's wrong on screenshot. Please provide a full request which you execute to get trips / stops data and a real location with time intervals of stops for unit.
(12/01/2021 16:09:09 отредактировано trushal.shah)
Diana пишет:
Hello, trushal.shah
Hello
thanks for the reply,
Sure i will do share more details with API call, response and mobile view with webview
In the share screenshots different is that
all location which we get as stop in the API are considered as Parking in the web,
so just want to know how we can get parking data stop data from the API
do we need to add any type like ignition?
When data are get via events(or in reports proceeded), there is not parking or stops events type, only trips (motion) detected by unit Trip Detector
The parkings/stops system is calculated additionally (you cannot get them via some API) :
The parkings are intervals between trips
For example   1st trip - 10:20 - 11:20
2nd trip  11:50 - 12:30
So the parking is 11:20 - 11:50
The stops are intervals inside trips where the speed is less then value Min moving speed.
For example, 1st trips - 10:20 - 11:20  where speed is less than 1 km/h (default value Min moving speed)  in messages from 10:21 till 10:24, so 3 minutes is stop.
(22/01/2021 10:15:47 отредактировано trushal.shah)
Hello
I do send this message to get track data of the unit same as wialon page
same as the first image and the second image
but we are struggling to get data. we applied the same login you suggest getting between time data
its not sufficient to get the same data as the web does we if we apply s<1 then we are getting all the stops which are not there in the website
below is API call we done
APi URL:
Dates select 11/01/2021 to 12/01/2021 and unit id as 11489
http://gps.tawasolmap.com/wialon/ajax.html?svc=core/batch&sid=bdfabd36adfb22323b0a292ceb799ed5&params={"params":[{"svc":"events/load","params":{"ivalType":1,"itemId":11489,"timeFrom":1609439400,"timeTo":1609525799,"detectors":[{"type":"trips","filter1":0},{"type":"ignition","filter1":0}]}},{"svc":"events/get","params":{"selector":{"type":"trips","timeFrom":1609439400,"timeTo":1609525799,"detalization":11}}},{"svc":"events/get","params":{"selector":{"expr":"trips{s<1}","timeFrom":1609439400,"timeTo":1609525799,"detalization":11}}}],"flags":0}
let me know token required
and also I have attached result we from API call
check attached images that we need same stop and parking would display as wialon web/track page has
Please help me with this would much appreciate
Иконка вложений Platinum till 6pm.docx 14.81 Кб, файл был скачан 350 раз(а)
The same different time interval in request  and on screenshot.
"timeFrom":1609439400,"timeTo":1609525799 :
Thu, 31 Dec 2020 18:30:00 +0000
Fri, 01 Jan 2021 18:29:59 +0000
On screenshot Jan 6, 00:00-18:00 (regarding users timezone).
You write about other dates Dates select 11/01/2021 to 12/01/2021
Sure you can get different result on different intervals.
You can open Developer Console and look which time(from/to) is passed in request to get track data.
(01/02/2021 16:05:20 отредактировано trushal.shah)
Hello
if you can please help me that what would be the format of the URL to send push notification on engine On and Off
    "t":"push_messages",    /* action type */
    "p":{
        "url":<text>,        /* server name (port may be defined), start it with "http(s)" */
        "get":<bool>        /* request type: 1 - GET, 0 - POST */
this is what I have set but not getting a notification
https://localhost.ip/front/api/v1/send_push?user=username&msg='Hello'
Do we need to attache message to send push, ot Wialon server would send same which we had set on the text
trushal.shah пишет:
Hello
    "p":{
Do we need to attach a message to send push, to Wialon server would send the same which we had set on the text
Hello Diana
if you can please help me in this its working with fire notification from firebase with the below URL
https://serverURL/front/api/v1/send_push?user=brainvire1
Method:  GET
But I am not getting from penal which saws fire of few notifications
trushal.shah пишет:
Hello
    "p":{
The URL for server is specified path with end point by which the GET/POST request from Wialon will be proceeded.
For example , at my server there is file php which proceeds GET request with some parameters , so at notification as URL I have specified the path to this file.
{t: "push_messages", p: {get: "1", url: "http://dinacheley.com/notif/index.php"}}
The parameters for GET/POST request are specified in notification text  as param1=some_value&param2=%some_wialon_tag%&.....
The parameters name/value  can be different.
(10/02/2021 08:59:28 отредактировано trushal.shah)
Hi, thanks for the replay this working fine, and we are getting notifications
But if I set the URL as this then getting as attached screenshot notification
https://localhost/front/api/v1/send_push?user=brainvire&msg=%UNIT%
and our requirement is to send message same
%UNIT% violated speed limitations. At %POS_TIME% it moved with speed %SPEED% near '%LOCATION%'.
How I can set this if you can please guide me
Hi!
If you need to get  a full string as text messages,  you can specify at notification (notification's text)  parameter with JSON object
For example,  msg={"spec":"%UNIT% unit and so on %some_other_wialon_tags%"}
So server should get parameter 'msg' with JSON value, and parse this JSON
(18/02/2021 14:08:55 отредактировано trushal.shah)
Diana пишет:
Hi!
Thanks for the update
the issue is with Notification text with space is not working
"txt":"Helllo UNITName%UNIT%Current_Location: %LOCATION%Current_Time%CURR_TIME%"
Notification got just Hello text rest of the message skip due to space, if we have remove all space then its working
like this "txt":"HellloUNITName%UNIT%Current_Location:%LOCATION%Current_Time%CURR_TIME%"
check the attached screenshot
trushal.shah пишет:
Diana пишет:
Hi!
"txt":"Helllo UNITName%UNIT%Current_Location: %LOCATION%Current_Time %CURR_TIME%"
like this "txt":"HellloUNITName%UNIT%Current_Location:%LOCATION%Current_Time %CURR_TIME%"
Try to type  URL-encoding %20  instead space
Diana пишет:
trushal.shah пишет:
Diana пишет:
Hi!
thanks for the reply but still looks its skip the notification text with space, even from penal also
txt: UNITName: %UNIT% Current_Location: %LOCATION% Current_Time %CURR_TIME%
encode text: UNITName%20%25UNIT%25%20Current_Location%20%25LOCATION%25%20Current_Time%20%25CURR_TIME%25
But still its skip with space
As I said before, it's better to send text as JSON parameter string type, i.e notification text is like paramName={"spec":"%UNIT% unit and so on %some_other_wialon_tags% some text with spaces"}
Sure the server should parse parameter paramName as JSON
In any case you should look through server parsing which get message from Wialon.
For example, our push server parse  any text from Wialon notifications, and users get the same text on mobile as in web interface.
Diana пишет:
Thanks for the support
review with both option but getting error
Normal URL
"act":[{"t":"push_messages","p":{"url":"https://tawasoul.brainvire.dev/front/api/v1/send_push?user=brainvire&msg=","get":1}}],"txt":{"spec":"%UNIT%"}
After encode
"act":[{"t":"push_messages","p":{"url":"https%3A%2F%2Ftawasoul.brainvire.dev%2Ffront%2Fapi%2Fv1%2Fsend_push%3Fuser%3Dbrainvire%26msg%3D","get":1}}],"txt":%7B%22spec%22%3A%22%25UNIT%25%7D,
Both case its not working
getting error
    "error": 4,
    "reason": "VALIDATE_PARAMS_ERROR: {n: text, txt: text, ta: uint, td: uint, ma: uint, mmtd: uint, cdt: uint, mast: uint, mpst: uint, cp: uint, fl: uint, tz: int, la: text, un: [long], sch: {f1: ushort, f2: ushort, t1: ushort, t2: ushort, m: uint, y: uint, w: uint}, trg: {t: text, p: {}}, act: [{t: text, p: {}}]}"
When you change notification , you need to send all parameters, not only changed.
Also the parameter "txt" value should be string, not object, so it needs ""
For example,
{"n":"dinacheley","ta":1614027600,"td":0,"tz":134228528,"la":"ru","ma":0,"sch":{"f1":0,"f2":0,"t1":0,"t2":0,"m":0,"y":0,"w":0,"fl":0},"ctrl_sch":{"f1":0,"f2":0,"t1":0,"t2":0,"m":0,"y":0,"w":0,"fl":0},"un":[20685653,21728414],"trg":{"t":"outage","p":{"type":"0","time":60,"check_restore":1}},"d":"","act":[{"t":"push_messages","p":{"url":"https://tawasoul.brainvire.dev/front/api/v1/send_push?user=brainvire&msg=","get":1}}],"txt":"{\"spec\":\"%UNIT%\"}","fl":0,"mast":0,"mpst":0,"cdt":0,"mmtd":3600,"cp":0,"id":124,"itemId":930849,"callMode":"update"}
Hello
How I can get running vehicle latest details in the below API
https://sdk.online.stavtrack.com/wiki/en/kit/remo … vents/load
like if the vehicle as in the parking then getting proper data of the duration of movement
but if in the running mode then also getting last parked data  not currently running data, if you can help me which flag i should add to get the latest running data with below API
Below post data i am using
{"params":[{"svc":"events\/load","params":{"detectors":[{"filter1":0,"type":"trips"}],"timeTo":1616092199,"ivalType":1,"timeFrom":1616005800,"itemId":65788}},{"svc":"events\/get","params":{"selector":{"detalization":11,"type":"*","timeFrom":1616005800,"timeTo":1616092199}}},{"svc":"events\/get","params":{"selector":{"timeFrom":1616005800,"detalization":11,"expr":"trips{s<1}","timeTo":1616092199}}}],"flags":0}&sid=fd3b1aff8d623662dfdd038effd7ab25
